I've been looking for a specific clarification, unable to find yet in documentation or existing threads.
Use case is a deployement of two 5412's in VSF configuration.
In a scenario where you have a routed VLAN for management (without the "vlan management" command enabled), that IP address is shared between the VSF members, always up.
If you enable OoBM-MAD for "split brain" detection, what is the recommended/best practice on IP addressing?
Assign IP on the same VLAN/subnet or use an entirely different?
Is that Control Plane traffic of the OoBM ports like a separate VRF?
Or its purpose is that it has to be in the MGMT subnet but will always stay up in the event of severe traffic congestion/loss, due to the separate Control Plane?
