Overview And Setup Of VXLAN On Aruba Switches
MVP
MVP
VXLAN:
  • VXLAN is a Layer 2 encapsulation technology that substitutes the usage of VLAN numbers to label Ethernet broadcast domains with VXLAN numbers.
  • VXLAN supports 224 Ethernet broadcast domains or VXLAN numbers. (16,777,216)
  • A VXLAN number ID is referred to as VNI. There is a one-to-one relationship between an Ethernet broadcast domain and a VNI.
  • A single Ethernet broadcast domain can’t have more than one VNI.
  • VXLAN requires two devices to create and terminate VXLAN tunnels. A device that can create or terminate the VXLAN tunnel is called the VXLAN Tunnel Endpoint (VTEP).
A VTEP performs these two roles:
  1. Receive Layer 2 traffic from a source, such as a VM, in an Ethernet broadcast domain, encapsulating it within a VXLAN frame and sending it to the destination
  2. VTEP.Receive the VXLAN frame, stripping the encapsulation to reveal the encapsulated Ethernet frame, and forwarding the frame toward the destination included in the encapsulated Ethernet frame.
  • VXLAN tunnel which carries the encapsulated data is called an overlay network
  • The IP physical network that switches and routes the tunnels that make up the overlay is called the underlay network.
Topology:
Devices Used:
2 x 5412R switches : Version - KB.16.08.0001
2 x Servers
The Clients connected to vlan 20 on both the switches need to communicate with each other,the switches are connected through a /30 network between them and no gateway is configured on the Servers.
The overlay network will be Vlan 20 and underlay is the vlan 1
Server Ping results from 10.0.20.10:
Config steps:
  1. Disable v2 modules
  2. Enable VXLAN
  3. Create a Virtual-network (VNI) and associate a vlan
  4. Create a Vxlan tunnel and define source and destination VTEP's
  5. Map the tunnel to a overlay network
SW-1:
  1. no allow-v2-modules
  2. vxlan enable
  3. virtual-network 300 20 "lll"   (vlan is 20 and VNI is 300)
  4. interface tunnel 1
       tunnel name "left"
       tunnel mode vxlan
       tunnel source 1.1.1.1
       tunnel destination 2.2.2.2
       exit
  5. vxlan tunnel 1 overlay-vlan 20
SW-1(config)# show ip
 Internet (IP) Service
  IP Routing : Disabled
  Default Gateway :
  Default TTL     : 64
  Arp Age         : 20
  Domain Suffix   :
  DNS server      :
                       |                                            Proxy ARP
  VLAN                 | IP Config  IP Address      Subnet Mask     Std  Local
  DEFAULT_VLAN         | Manual     10.0.1.1        255.255.255.252  No    No
  VLAN20               | Disabled
                               Loopback Interface
  Loopback     | IP Config    IP Address      Subnet Mask
           lo1 | Manual                1.1.1.1 255.255.255.255
SW-1(config)# show ip route
                                IP Route Entries
  Destination        Gateway         VLAN Type      Sub-Type   Metric     Dist.
  1.1.1.1/32         lo1                  connected            1          0
  2.2.2.2/32         10.0.1.2        1    static               1          1
  10.0.1.0/30        DEFAULT_VLAN    1    connected            1          0
  127.0.0.0/8        reject               static               0          0
  127.0.0.1/32       lo0                  connected            1          0
SW-2:
  2. vxlan enable
  4. interface tunnel 2
       tunnel name "right"
       tunnel mode vxlan
       tunnel source 2.2.2.2
       tunnel destination 1.1.1.1
       exit
  5. vxlan tunnel 2 overlay-vlan 20
SW-2(config)#  show ip
  Default Gateway :
  Default TTL     : 64
  Arp Age         : 20
  Domain Suffix   :
  DNS server      :
                       |                                            Proxy ARP
  DEFAULT_VLAN         | Manual     10.0.1.2        255.255.255.252  No    No
  VLAN20               | Disabled
                               Loopback Interface
           lo2 | Manual                2.2.2.2 255.255.255.255
SW-2(config)# show ip route
                                IP Route Entries
  1.1.1.1/32         10.0.1.1        1    static               1          1
  2.2.2.2/32         lo2                  connected            1          0
Server 1:
Ethernet adapter ZZ. Test Network:
   Connection-specific DNS Suffix  . :
   Link-local IPv6 Address . . . . . : fe80::8cd5:177c:48e6:ddc1%13
   IPv4 Address. . . . . . . . . . . : 10.0.20.9
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Default Gateway . . . . . . . . . :
Server 2:
   Link-local IPv6 Address . . . . . : fe80::4480:f068:e9c8:9dc%13
   IPv4 Address. . . . . . . . . . . : 10.0.20.10
SW-1 :
SW-1(config)# show vxlan
  VXLAN Tunnel Information
  Status              : Enabled
  UDP Port            : 4789
SW-1(config)# show interfaces tunnel 1
 Tunnel Configuration :
  Tunnel               : 251659490
  Tunnel Name          : VXLAN_Tunnel01
  Tunnel Status        : Enabled
  Source Address       : 1.1.1.1
  Destination Address  : 2.2.2.2
  Mode                 : VXLAN Tunnel
  TOS                  : -1
  TTL                  : 64
  IPv6                 : n/a
  MTU                  : 1450
 Current Tunnel Status :
  Tunnel State              : Up
  Destination Address Route : 2.2.2.2/32
  Next Hop IP               : 10.0.1.2
  Next Hop Interface        : vlan-1
  Next Hop IP Link Status   : Up
  Egress Port               : A1
SW-1(config)# show interfaces tunnel type vxlan statistics 251659490
  Rx Packets                                   : 505
  Tx Packets                                   : 87973812
  Rx 5 Minute Weighted Average Rate (Pkts/sec) : 0
  Tx 5 Minute Weighted Average Rate (Pkts/sec) : 0
SW-2:
SW-2(config)# show vxlan
  Status              : Enabled
  UDP Port            : 4789
SW-2(config)# show interfaces tunnel 2
  Tunnel               : 251659490
  Source Address       : 2.2.2.2
  Destination Address  : 1.1.1.1
  Mode                 : VXLAN Tunnel
  TOS                  : -1
  TTL                  : 64
  IPv6                 : n/a
  MTU                  : 1450
  Tunnel State              : Up
  Destination Address Route : 1.1.1.1/32
  Next Hop IP               : 10.0.1.1
  Egress Port               : A1
SW-2(config)# show interfaces tunnel type vxlan statistics 251659490
  Rx Packets                                   : 87973901
  Tx Packets                                   : 588
SW -2 config.txt
SW-1 config.txt
Version history
Revision #:
1 of 1
Last update:
‎07-29-2019 07:01 AM
Updated by:
