Wired Intelligent Edge
Policy Based Routing from comware switch to ArubaOS Switch
  • 1.  Policy Based Routing from comware switch to ArubaOS Switch
    Posted Feb 28, 2019 03:29 PM
    I have this PBR configuration of an HP comware switch, how can I translate it to ArubaOS Switch?
    policy-based-route correoserver deny node 1
    if-match acl 3100
    apply ip-address next-hop 192.168.20.1
    policy-based-route correoserver permit node 3
    if-match acl 3102
    apply ip-address next-hop 192.168.20.254
    policy-based-route bancocajasocial deny node 1
    if-match acl 3000
    apply ip-address next-hop 172.17.0.1
    policy-based-route bancocajasocial permit node 3
    if-match acl 3002
    policy-based-route routingWIFI deny node 1
    if-match acl 3200
    apply ip-address next-hop 172.18.0.2
    policy-based-route routingWIFI permit node 3
    if-match acl 3202
    apply ip-address next-hop 172.18.120.1
    policy-based-route routingISSABEL permit node 1
    if-match acl 3404
    apply ip-address next-hop 10.0.0.199
    policy-based-route routingISSABEL deny node 2
    if-match acl 3400
    policy-based-route routingISSABEL permit node 3
    if-match acl 3402
    policy-based-route routingACADEM deny node 1
    if-match acl 3500
    apply ip-address next-hop 172.16.0.1
    policy-based-route routingACADEM permit node 3
    if-match acl 3502
    apply ip-address next-hop 172.16.120.1
  • 2.  RE: Policy Based Routing from comware switch to ArubaOS Switch
    Posted Mar 01, 2019 01:06 PM
    Greetings!
    This CLI Reference Guide covers both ArubaOS-Switch and Comware, and should help with translation of commands between platforms.
  • 3.  RE: Policy Based Routing from comware switch to ArubaOS Switch
    Posted Mar 01, 2019 01:28 PM
    Hello Matthew.
    I just reviewed the CLI Reference manual, and I can not find any indication of the "policy-based-route" command and its corresponding translation, how can we do this translation?
  • 4.  RE: Policy Based Routing from comware switch to ArubaOS Switch
    Posted Mar 01, 2019 01:49 PM
    Refer to the Creating a PBR Policy section of the Advanced Traffic Management Guide.
    The ArubaOS-Switch PBR implementation uses traffic classifiers rather than ACLs for matching in PBR policies, so you would need to migrate the contents of your ACLs to traffic classes and use those to apply your next-hop actions in the PBR policy (use the examples in the linked document as a guideline).
