Port Latency for Aruba 8400
Hi pals.
Some vendors claim to have very low latency between ports on the same chassis. The term they use is "any-port-to-any-port latency".
Does Aruba 8400 have test results for latency between its ports?
All documentation for Aruba 8400 only says "very low latency" but do not offer any proof of that latency with a test report.
Regards
PS: If you feel this information is useful and solved your question or problem, please do not forget to mark it as a solution and give me some kudos.
MVP Guru
Re: Port Latency for Aruba 8400
Latency of 8400 any-port-to-any-port is 4 microsecond.
Hi Vincent,
Is there any documentation to support your answer?
Kind regards
MVP Guru
These are internal testing.
There is not yet public third party test I could share with you.
Thank you so much for your answer Vincent.
Have a great week.
