MVP Expert
PowerArubaCX : a powershell module for use ArubaCX REST API
I have been working for several months on a Powershell module that uses the ArubaCX REST API.
This module is available on psgallery(.com) : https://www.powershellgallery.com/packages/PowerArubaCX/
Actually, we support to connect to HTTPS using login/passwrd
and get the following feature :
  • System
  • Ports
  • Vlans
  • LLDP Neighbor
it is very easy to use (and install)
Launch powershell command line and launch following command for install
Install-Module PowerArubaCX
for load the module
Import-Module PowerArubaCX
Connect to your Aruba CX
Connect-ArubaCX 192.0.2.1
You need to use -SkipCertificateCheck if the certificate is not valid
for example to get system info
Get-ArubaCXSystem
Like the API, it is possible to select what need to display (configuration, status, statistics) using -selector parameter
for example to get system info statistics
Get-ArubaCXSystem -selector statistics
You can also select what you want to display using -attributes parameter
For example to display hostname and dns servers of system
Get-ArubaCXSystem -attributes hostname,dns_servers
for Ports or Interfaces, it is also possible to choice the depth (from 0 to 3)
Get-ArubaCXPorts -depth 1
You can get the list of command available via
Get-Command -Module PowerArubaCX
 and for get help (and example about a command for example ArubaCXLLDPNeighbor)
Get-Help Get-ArubaCXLLDPNeighbor -Full
It is already compatible with PowerShell 6 (Core) and macOS/Linux !
More documentation, example is available on https://github.com/PowerAruba/PowerArubaCX and you can also report issue/enhance !
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
ACMP 6.4 / ACMX #107 / ACCP 6.5
