MVP Expert
Re: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
@tbig wrote:
I apologize if this should be a separate thread vs a question on your PS module:
I'm trying to determine if the REST API for ArubaOS allows toggling the PoE state on a given port?  Aka: Port E6: turn off PoE.
If it's possible, can someone give a syntax example for the request?
Hi tbig,
There is already a "issue" on GitHub about PoE function
https://github.com/PowerAruba/PowerArubaSW/issues/71
There is already the command for get PoE Status...
and it will no be complicated to change status (need to look API docs)
I think include PoE for 0.8 or 0.9...
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
ACMP 6.4 / ACMX #107 / ACCP 6.5
Just to confirm, does the REST API support a change to the PoE state?
Documentation I saw referenced a post command to the PoE end point, but it
wasn't clear how it works, if at all.
I'd be grateful to see a curl command or anything if it's currently possible
MVP Expert
from the doc, yes it is possible
You need to use uri : .../poe/ports/{PortPoe.port_id}/reset with HTTP method "POST"
Hmm... the only version of the API where I see that endpoint referenced in is from "Aruba REST API Guide for ArubaOSSwitch 16.05"
https://support.hpe.com/hpsc/doc/public/display?docId=a00040422en_us
Also, when you get to the end of the section it says:
Note: Applicable only for ArubaOS-Switch 5400R.
Are you looking at any other version of the OS or a different API doc?
(Sorry this is my last question!) :D
MVP Expert
There is some typo on this doc...
You need to look : 16.08 REST API and JSON Schema (for example : https://h10145.www1.hpe.com/downloads/DownloadSoftware.aspx?SoftwareReleaseUId=24618&ProductNumber=JL557A&lang=&cc=&prodSeriesId=&SaidNumber= )
Just to close the loop - thanks, the link you provided was a huge help.
We're on 16.03, and I don't see that reset method available (and I get a 404 error when trying it).  I do see it in the 16.08 schema, and we're likely to be upgrading soon to that, at which point I can test further.
At any rate, thanks for clearing some of the fog. :D
MVP Expert
I need to check because i get same strange issue when try PoE reset API...
MVP Expert
a new release is available (0.8.0)
What new ?
14 new cmdlets !
For Trunk, STP, PoE, IP Address (Get only)...
There is also the support of AnyCli and cliBatch
For example
Get-ArubaSWCli -cmd "show running"
and one of major feature of this release it is the support of multi-connection. it is possible to connect to multiple switch on same time using -connection parameter
for example
$sw1 = Connect-ArubaSW 192.168.0.1
$sw2 = Connect-ArubaSW 192.168.0.2
After for get vlans
Get-ArubaSWVlans -connection $sw1
Get-ArubaSWVlans -connection $sw2
More info => https://github.com/PowerAruba/PowerArubaSW/releases/tag/v0.8.0
