Occasional Contributor I
QOS implementation
Hi Everyone!
I am implementing QOS on 2930F but not able to get enough information in the configuration guide.
Any suggestions would be of great help. Thank you!
Re: QOS implementation
Would be great if you can explain what you are trying to achieve.
Ch#7 of following books covers QoS in detail:
https://support.hpe.com/hpsc/doc/public/display?docId=a00038764en_us
JayBee
ACDX | ACCX| CCIE (RnS/SP,DC) | ACCP | ACMP | ACSA | ACMA | CWNA | JNCIS | JNCIA
If the provided solution resolves your issue, please mark it as accepted solution to help others.
Hi Rakesh
If you are a partner, you can also find useful information in Arubapedia for Partners:
https://afp.arubanetworks.com/afp/index.php/Understanding_QoS_in_ArubaOS-Switch
https://afp.arubanetworks.com/afp/index.php/Quality_of_Service
https://afp.arubanetworks.com/afp/index.php/QoS_for_Voice_Deployment_Guidelines
Regards
PS: If you feel this information is useful and solved your question or problem, please do not forget to mark it as a solution and give me some kudos.
Thanks for the response!
I was trying to mimic the auto qos implementation of Cisco on Aruba & i dint see any supporting/relating commands for Aruba. I guess that leaves me to manualy configure & keep qos consistent across the switched network  & I was searching for relevant documents.
Hi Rakesh,
Maybe this discussion could help you:
https://community.arubanetworks.com/t5/Wired-Intelligent-Edge-Campus/ARUBA-SWITCH-AND-IP-PHONES/m-p/309892#M2398
Here you can find an external link with some information about a similar commad to Cisco Auto QoS.
Regards
