QoS confirmation
I have raised a couple of posts on the forums about VLAN and QoS priority so far and the feedback has been very helpful and positive so far so thank-you.
Only one little point I would like some feedback from. I am using an Aruba 2530 (J9780A) switch and want to concerntrate on the layer 2 for this query.
Basically I want to confirm my QoS configuration so far.
My VLAN's work fine (I get split networks on 2 different IP ranges) so am happy with the VLAN'S, despite the fact I cannot see a VLAN tag in the Wireshark trace (I am running a mirror port on the VLAN trunk/uplink/tagged port) I also cannot see any priority tagging for traffic in Wireshark either.
I run the command on the Aruba "show qos vlan-priority" and get the below:
VLAN-based Prioritization
VLAN ID Apply rule | DSCP Priority
1 No-override | No-override
40 Priority | 5
My VLAN configuration shows this priority set also (some un-relevant entries removed):
vlan 40
name "VOICE"
qos priority 5
voice
Obvously confirmation would be that I get crystal clear voice on a call without dropped packets, but was just wondering if anyone had anything to confirm these points on a switch level before going live with the customer.
Anyone with an experience of finding these packets on Wireshark also I would be keen to hear your points. And I have checked the Wireshark forum also.
Re: QoS confirmation
Are you using Wireshark on a Windows PC? In my experience, Windows NIC drivers do not pass the DSCP or CoS tagging on packets. When I was setting up and testing QoS for our VoIP system, I ended up using a laptop with Kali Linux installed to do my Wireshark captures. I believe other flavors of Linux will work for this as well.
Thanks for responding, that is a very interesting point that I was not aware of. I am using a Windows machine for running Wireshark for simplicitys sake.
I can however run Linux with T-shark and see if I get a positive result I will update shortly.
MVP Expert
it is good ?
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
ACMP 6.4 / ACMX #107 / ACCP 6.5
