Question about * after show interface brief
Ref. Image below.
About aruba switch 5406
After running command #Show interface breif
Ex.1
B1*   SFP+DAC
B2*   SFP+DAC
B3   SFP+DAC
What that mean about  " *  " ?
Ex.2
B6*   SFP+DAC
B7   SFP+DA5
What " DA5" mean?
Thank for answer.
good day.
MVP Expert
Re: Question about * after show interface brief
DA5 it is not because a DAC cable with 5meters ?
and * because it is a LACP ?
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
ACMP 6.4 / ACMX #107 / ACCP 6.5
