Highlighted
Radius server config - Aruba2930M
Hello All,
I am new to the Aruba environment and am trying to setup a lab environment for simulating bare basic 802.1X wired authentication using clearpass.
For some reason i think the 2930M switch is not communicating back to the Radius server.
After reading the Clearpass wired policy enforcement doc -  i tried configuring the switch for 802.1x, but still no luck. I am sure i am missing something here.
Below is what my config looks like :
radius-server host 10.130.110.19 key "Aruba123!"
radius-server host 10.130.110.19 dyn-authorization
radius-server host 10.130.110.19 time-window plus-or-minus-time-window
radius-server host 10.130.110.19 time-window 30
ip default-gateway 10.76.138.1
ip source-interface radius vlan 2073
ip client-tracker trusted
snmp-server community "public" unrestricted
aaa server-group radius "CLEARPASS" host 10.130.110.19
aaa accounting update periodic 5
aaa accounting network start-stop radius server-group "CLEARPASS"
aaa authorization user-role enable download
aaa authentication port-access eap-radius server-group "CLEARPASS"
aaa authentication captive-portal enable
aaa port-access authenticator 1/5
aaa port-access authenticator 1/5 client-limit 3
aaa port-access authenticator active
And below is the output from the show radius command.
SHOW RADIUS HOST 10.130.110.19
Status and Counters - RADIUS Server Information
Server IP Addr : 10.130.110.19
Authentication UDP Port : 1812 Accounting UDP Port : 1813
Round Trip Time : 0 Round Trip Time : 0
Pending Requests : 0 Pending Requests : 0
Retransmissions : 18 Retransmissions : 0
Timeouts : 21 Timeouts : 0
Malformed Responses : 0 Malformed Responses : 0
Bad Authenticators : 0 Bad Authenticators : 0
Unknown Types : 0 Unknown Types : 0
Packets Dropped : 0 Packets Dropped : 0
Access Requests : 6 Accounting Requests : 0
Access Challenges : 0 Accounting Responses : 0
Access Accepts : 0
Access Rejects : 0
Can anyone see what i am missing here ? I can also ping the Radius host from the switch.
Thanks.
Accepted Solutions
Highlighted
Re: Radius server config - Aruba2930M
Thank you for your reply :)
I figured it out late night when i tore down the AAA connection on the switch , and reconfigured it.
It turns out - it was an issue with Clearpass server Radius certificate/HTTPs certificate !
I created a new self-signed certificate and instantly i could see responses on the "Access tracker" on clearpass from the switch.
However i have to admit the switch logs were quite misleading - "Cant reach the Radius server : X.X.X.X ".
Thanks again !
View solution in original post
All Replies
Highlighted
MVP Guru Elite
Do you have check the shared secret ?
What do you have on ClearPass log ? (and event ?)
There is no firewall between ClearPass and switch ?
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
Thanks again !
Highlighted
MVP Guru Elite
Strange about issue on the certificate...
