Occasional Contributor I
Routed links with VLANs and can’t ping the Management IP...
Hi all!
I am kind of new to Aruba and learning... I have a question though and can’t figure out what I’m missing...
I have 3 2930f switches in 3 locations that are linked together. A and b are connected on a vlan with each interface having an ip, b and c are connected in a vlan with each interface having an ip and same for C and A.
I can ping and remotely connect to the vlan IPs, but I cannot ping or remotely connect to the switches with the management IP... any suggestions?
MVP Expert
Re: Routed links with VLANs and can’t ping the Management IP...
can you share the config ?
do you have a schema ?
do you don't have forget default gateway ? or enable management vlan ?
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
ACMP 6.4 / ACMX #107 / ACCP 6.5
Basically we have two 2930F.
Interface 28 on both is the interface connecting the two.
Each switch has a different IP on VLAN 1.
We are using a vlan with a /30 subnet that has interface 28 untagged  on both.
Traffic flows fine, but I can only ping and remotely connect to the IP of the interface 28 (We are using RIP as well).
I am trying to figure out how I can ping the IP of VLAN 1 which I am not able to do, but all else is good... If that makes sense...
MVP Expert
Greetings!
Is there a route from your management system to the VLAN 1 IP address on each of the switches you're trying to access? You may need to check other switches and/or routers to verify that these routes are being properly redistributed via RIP.
If that route is there, next verify that there is a route back to the management system IP/subnet from the switch itself. Use the 'show ip route' command in the switch CLI:
switch# show ip route
        IP Route Entries
  Destination        Gateway         VLAN Type      Sub-Type   Metric     Dist.
  0.0.0.0/0          10.5.7.1        57   static               1          1
  10.5.7.0/24        Mgmt            57   connected            1          0
  127.0.0.0/8        reject               static               0          0
  127.0.0.1/32       lo0                  connected            1          0
Verify that you either have a specific route that includes the subnet where the management system is located, or that the default router is capable of routing back to that system.
Matt Fern
Technical Marketing Engineer, Wired Intelligent Edge
Aruba, a Hewlett Packard Enterprise company
8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747
T: 916.540.1759  |  E: mfern@hpe.com   |   Matt @ Twitter
It has been a little bit, I am still working on this though. I am going to check the routing.
The set up is 3 switches. A, B and C. A is the main one. A is connected to B by a /30 subnet. B is connected to C with a /30 subnet as well. The switches are running RIP. The two interfaces that connect the switches are setup as untagged on VLAN 1 only.
I can ping VLAN 1 from B and C back to A. If I am on any of the switches, I cannot ping VLAN 1 on the other switch though... I saw the a message about the default gateway, but I cannot do that unless I disable the routing.
MVP Expert
if routing is enable you need to use ip static route 0.0.0.0...
Once I connected a device to the switch and put it on that VLAN I was able to ping the management IP/ VLAN...
MVP Expert
do you have check the (default) gateway ?
