Wired Intelligent Edge
Routing issue from 2930f trhough stack of 3810ms failing.
  • 1.  Routing issue from 2930f trhough stack of 3810ms failing.
    Posted Nov 05, 2019 11:13 AM
    Just hoping someone could help with a problem we are having with our switch config.
    Basically we have a stack of 4 3810m’s. Port 1/1 is connected to a Sophos firewall. Ports 1/2 and 2/2 are connected to ports 49 and 50 on a 2930f
    The Sophos firewall has an ip of 172.16.98.2 and this can be pinged from the core stack. The core stack can also ping the outside world.
    However the 2930f can’t ping the Sophos or the outside world.
    The default gateway on the 2930f is set to 10.0.0.1 so any traffic outside the 10.0.0.0/24 subnet should route through the core and then the ip route setting on that switch should route basically everything through to the Sophos.
    Below are the configs for the switches. Any ideas?
    Running configuration:
    ; hpStack_KB Configuration Editor; Created on release #KB.16.07.0003
    ; Ver #14:01.4f.f8.1d.fb.7f.bf.bb.ff.7c.59.fc.7b.ff.ff.fc.ff.ff.3f.ef:4e
    stacking
       member 1 type "JL075A" mac-address 9020c2-e28000
       member 2 type "JL075A" mac-address 9020c2-e1bc80
       member 3 type "JL075A" mac-address 9020c2-e2f880
       member 4 type "JL075A" mac-address 9020c2-e20600
       exit
    hostname "CORE"
    trunk 1/2,2/2 trk1 lacp
    ip route 0.0.0.0 0.0.0.0 172.16.98.2
    ip routing
    snmp-server community "public" unrestricted
    oobm
       ip address dhcp-bootp
       member 1
          exit
       member 2
          exit
       member 3
          exit
       member 4
          exit
       exit
    vlan 1
       name "DEFAULT_VLAN"
       no untagged 1/1
       untagged 1/3-1/16,2/1,2/3-2/16,3/1-3/16,4/1-4/16,Trk1
       ipv6 enable
       ipv6 address dhcp full
       exit
    vlan 98
       name "VLAN98"
       untagged 1/1
       ip address 172.16.98.1 255.255.255.0
       exit
    vlan 120
       name "TEMP"
       tagged Trk1
       ip address 10.0.0.1 255.255.255.0
       exit
    spanning-tree Trk1 priority 4
    ; JL256A Configuration Editor; Created on release #WC.16.07.0003
    ; Ver #14:01.4f.f8.1d.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:02
    hostname "Aruba-2930F-48G-PoEP-4SFPP"
    module 1 type jl256a
    trunk 49-50 trk1 lacp
    ip default-gateway 10.0.0.1
    no ip source-route
    vlan 1
       name "DEFAULT_VLAN"
       no untagged 1
       untagged 2-48,51-52,Trk1
       ipv6 enable
       exit
    vlan 120
       name "TEMP"
       untagged 1
       tagged Trk1
       ip address 10.0.0.2 255.255.255.0
       exit
  • 2.  RE: Routing issue from 2930f trhough stack of 3810ms failing.
    MVP GURU
    Posted Nov 06, 2019 05:03 PM
    Hi!
    Does the Sophos Firewall (172.16.98.2) know how to reach subnet 10.0.0.0/24? in other terms...on Sophos did you configure a static route to 10.0.0.0 255.255.255.0 net destination via 172.16.98.1 hop?
    Considering that:
    (1) the Aruba 2930F is just a Layer 2 extension (through aggregated logical interface tagged on VLAN 120 on both ends of the link) of your stacked Core for VLAN 120.
    (2) the Aruba 2930F uses 172.16.98.2 as its Default Gateway (which is the VLAN SVI on the stacked Core for VLAN 120).
    (3) your Stacked Core has Gateway of Last Resort properly set to point to Sophos Firewall (represented by the static route 0.0.0.0/0.0.0.0 to 172.16.98.2)
    If your Sophos Firewall is then properly instructed on how to route back to routed nets defined on stacked Core it should work as you correctly expect.
  • 3.  RE: Routing issue from 2930f trhough stack of 3810ms failing.
    Posted Nov 07, 2019 04:18 AM
    Cheers for the answer Parnassus. It was a routing issue back from the Sophos. The static route was configured but another interface was configured on the same 10.0.0.0/24 subnet which messed the routing up. Removed that interface configuration and it all magically started working.
  • 4.  RE: Routing issue from 2930f trhough stack of 3810ms failing.
    MVP GURU
    Posted Nov 07, 2019 04:32 AM
    I'm glad that you solved!
