Highlighted
Re: Routing issues Aruba 8320
Hi
How is the vsx status?
Cheers, Frank
AirHeads MVP |AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
Highlighted
@mrtwentytwo wrote:
Hi
Did you try:
Different software?
Only one core active?(sketch off one core)
Add a default route?
Sorry what do you mean by different software?
I've got a simple vigor router out which im going to setup to simulate the customers firewall and make it the default route for the switch. Still i didnt think id need to do this to get inter-vlan routing working.
Highlighted
@mrtwentytwo wrote:
Hi
All looks good. Both primary and secondary are in sync and active.
Im not at the switches right now or i would post the results
Highlighted
Hi
You are running 10.02.0010. did you try 10.02.0001?
Cheers, Frank
Highlighted
@mrtwentytwo wrote:
Hi
I was running that, but i upgraded to the latest as support told me to because the serial port was faulty, in the end it was hardware related. Ive only ever used 10.02.00010 when ive had VSX and vlan interfaces in play.
Highlighted
as per always this issue was something really stupid. My laptop was doing some weird routing. From the esxi host i could ping every gateway and even my laptop... once id turned the windows firewall off. Derp!
View solution in original post
Highlighted
Hi
Thanks for the update!
Cheers, Frank
Highlighted
There is something I don't quite understand. The interface mgmt should be isolated as ArubaosCX use the vrf mgmt for the management plane which should be isolated but yet you say that from any access port on vlan 60 you can ping 192.168.60.11?. You have an overlapping range 192.168.60.0/24 both on the management and your routing table but that shouldn't matter as they are in different vrf. Not sure if this is related, maybe if you try changing your mgmt IP to remove the overlapping?
- Daniel Tudares (ACSA)
Highlighted
Hi
It is already solved. I think the management interface in connected to a port I tagged in vlan 60. So it is isolated only connected through a wire
Cheers, Frank
