Hello, After setting up a s1500 switch using the quit setup through the CLI I am not able save the startup config.
I issue a copy running config to startup config command that says it completed sucess fully. When I show the startup config it still show the defauls. I recent purchased 3 used s1500s and they all exhibt the same symtoms.
Anyone out there having a simular problem?
