MVP Expert
SFP SX Transceivers: clarification about C/D Hardware revisions 4x4 Part Numbers
Hi all,
I need just a confirmation, are associations reported below:
  • SKU Part Number J4858C has 4x4 Part Number 1990-4415
  • SKU Part Number J4858D has 4x4 Part Number 1990-4395
correct?
Looking at any recent ArubaOS-Switch and ArubaOS-CX Transceiver Guide it seems the contrary given the way they are listed (which, I know, isn't correct), as example see here:
J4858C_D_SFP_Transceivers.pngand here:
Looking the way those items are reported it looks like the J4858C has 1990-4395 and J4858D has the 1990-4415.
MVP Expert
Re: SFP SX Transceivers: clarification about C/D Hardware revisions 4x4 Part Numbers
Greetings!
For clarification: both J4858C and J4858D may use either of the two listed 4x4 part numbers — it is not a one-to-one mapping. (If this were the case, they would be listed in separate rows in the chart.)
Matt Fern
Technical Marketing Engineer, Wired Intelligent Edge
Aruba, a Hewlett Packard Enterprise company
8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747
T: 916.540.1759  |  E: mfern@hpe.com   |   Matt @ Twitter
MVP Expert
Hello Matthew, thank you for clarifying me that (that was exactly the other possible option)...maybe I was too focused on finding a nonexistent 1:1 mapping!
So...the only way to verify about which Hardware revision (C or D) an HP/HPE/Aruba SFP SX Transceiver (I'm only focused on this one) is to look at its SKU (Prod #) and not at its 4x4 (Part #), both reported by show tech transceivers command.
Thank you again.
