SPF+ that will be compatible to connect to Cisco 10G-LRM SFP
What SPF+ tranciever will I be able to use to connect to existing Cisco access switches with 10G-LRM trancievers. The J9150D tranceiver don't work unless we replace the Cisco side with and 10G-SR. But we dont have enough SR for all the switches. Will teh J9152D work in this case? Pleae give me a part number for Aruba 10Gbe SFP+ transciever we an use in teh 5400R to connect to Cisco 10G-LRM. I don't wnat to buy something and it still doesnt work.
Re: SPF+ that will be compatible to connect to Cisco 10G-LRM SFP
J9152D will work
Look at table 1 entry 2:
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/data_sheet_c78-455693.html
And look at:
https://www.google.com/url?sa=t&source=web&rct=j&url=https://support.hpe.com/hpsc/doc/public/display%3FdocId%3Demr_na-c05115518&ved=2ahUKEwiLx7KGv9jhAhUPyFkKHUeACkQQFjAAegQIBRAC&usg=AOvVaw1_QijqcfXJ-6He4cfO93Eo
Tables 3 and 16
Specifications match
Regards
PS: If you feel this information is useful and solved your question or problem, please do not forget to mark it as a solution and give me some kudos.
Thank you. That was very helpful.
