Switch: 2930F SFP PoE+ (JL261A)
Module:1000T-sfp (J8177D)
AOS:WC.16.10.0005
Hi, two days ago I was configuring a 2930F SFP uplink interface and had to force it to 100 Mbps and auto duplex. I located a 1 Gbps port for testing, but when I tried to reset the speed/duplex settings for the 2930's SFP interface I received a message that said that such settings couldn't be configured on this port.
I tried disabling the port to try changin to full auto setting or forced 1000, but it didn't work. I tried with one of the 1-24 interfaces and the command was accepted without problem.
Finally, out of nowhere I tried again AFTER removing the J8177D module and, finally, I was able to change speed/duplex settings for the interface.
Is this a normal and expected behaviour for SFP and/or SFP+/28/56 interfaces?
Thanks in advance.
#2930F
