Highlighted
Stateful DHCPv6 support for wired networks
It does not seem the stateful DHCPv6 feature is supported for wired networks using Aruba switches. Has anybody had success setting up stateful DHCPv6 for their wired environment?
Switch Model we are using is:
3810M-40G-8SR-PoE
Software version we are running is:
show version
Image stamp:    /ws/swbuildm/rel_yakima_qaoff/code/build/bom(swbuildm_rel_yakima_qaoff_rel_yakima)
                Nov 21 2018 05:13:08
                KB.16.08.0001
                468
Boot Image:     Primary
Boot ROM Version:    KB.16.01.0009
Active Boot ROM:     Primary
ADSB-106-MDF(config)# show flash
Image             Size (bytes) Date     Version
Primary Image    :    34017600 11/21/18 KB.16.08.0001
Secondary Image  :    34017600 11/21/18 KB.16.08.0001
Boot ROM Version
Primary Boot ROM Version   : KB.16.01.0009
Secondary Boot ROM Version : KB.16.01.0009
Default Boot Image   : Primary
Default Boot ROM     : Primary
Also using the helper command to reach the DHCPv6 server:
Here is the switch configuration:
show running-config vlan 1000
Running configuration:
vlan 1000
   name "PROD"
   tagged 1/20,2/21
   untagged 3/20,3/30
   ip helper-address x.x.x.x
   ip address x.x.x.x 255.255.255.0
   ip igmp
   ip ospf x.x.x.x passive
   ip ospfx.x.x.x area 0.0.0.1
   ipv6 enable
   ipv6 address x:x:x:x::1/64
   ipv6 ospf3 passive
   ipv6 ospf3 area 0.0.0.1
   ipv6 nd ra managed-config-flag
   ipv6 helper-address unicast x:x:x:x::100
   jumbo
   exit
dhcpv6-relay
We are running dual stack and DHCPv4 works fine. For v6 end user clients get the prefix portion of the network correct, but uses SLAAC to generate the last /64 bit host portion of the address. Even when having the M flag set to 1, clients are not getting assignment from the v6 server.
Highlighted
Re: Stateful DHCPv6 support for wired networks
Hi, DHCPv6 stateful does work with ArubaOS-Switch, I've done quite a bit of work on it.
What client OS are you using? Android and, I believe, chromebooks do not support DHCPv6.
Are you able to get a packet capture from the client to see if the DHCPv6 SOLICIT and REPLY are being exchanged?
