Hi!
I have a 2530 switch in which I need to use VLAN 1 (primary VLAN) to sync with external NTP (Google's) and to connect with Central in the future.
However, it seems it is mandatory to have a DHCP IP address for the VLAN interface in the primary VLAN in order to have a default IP route to get into Internet:
HP-2530-48G-PoEP(vlan-1)# sh ip route
IP Route Entries
Destination Gateway VLAN Type Sub-Type Metric Dist.
0.0.0.0/0 172.19.17.253 1 static 250 1
127.0.0.0/8 reject static 0 0
127.0.0.1/32 connected 1 0
172.19.17.0/24 DEFAULT_VLAN 1 connected 1 0
The problem that I see is that I need a static IP address within this same VLAN for local management, apparently seconday IP addresses cannot be configured in this model nor I can configure loopback interfaces.
Is there any other way to accomplish this need for a fixed management IP?
Thanks in advance.
#2530
