Wired Intelligent Edge
Support for MILJET DAC on Aruba 2930F
  • 1.  Support for MILJET DAC on Aruba 2930F
    Posted Dec 16, 2019 06:43 AM
    Does Aruba 2930F supports this DAC cables?
    https://www.miljet.net/produto/mj-sfp-h10gb-cu3m/
    I have connected in my switch but they were not working. They are shown in 'show tech transceiver' but they are marked as unsupported (or SFP_UNKNOWN).
    Then I ran 'allow-unsupported-transceiver'. Still I have got no link from the transceiver. Trying a supported transceiver worked fine.
    Is there any other command that would work. Maybe a firmware update?
    Thanks.
  • 2.  RE: Support for MILJET DAC on Aruba 2930F
    Posted Dec 16, 2019 06:44 AM
    did you re boot after the allow-unsupported-transceiver command?
  • 3.  RE: Support for MILJET DAC on Aruba 2930F
    Posted Dec 26, 2019 11:34 AM
    No. I will try.
    Does the docs mention it?
  • 4.  RE: Support for MILJET DAC on Aruba 2930F
    MVP GURU
    Posted Dec 26, 2019 03:21 PM
    Hi! first thing first: The one we are referring about is an unsupported feature...it does not imply “support” for a non-certified transceiver...so you can't really expect that allowing something unsupported shall make any Transceiver to work. There is no guarantee.
    Documantation (https://community.arubanetworks.com/aruba/attachments/aruba/CampusSwitching/3089/1/ARUBAOS-SWITCH%25252520UNSUPPORTED%25252520TRANSCEIVER%25252520GUIDE%25252520V2.pdf) says so (it could have been written better).
  • 5.  RE: Support for MILJET DAC on Aruba 2930F
    Posted Dec 27, 2019 07:35 AM
    Unfortunately even after restart the transceiver still show as not supported.
    Does 2930F supports copper transceivers? I do believe so because of https://support.hpe.com/hpsc/doc/public/display?docId=emr_na-c05235854
    But this https://community.arubanetworks.com/t5/Wired-Intelligent-Edge-Campus/How-to-display-detailed-interface-transceiver-information-on/ta-p/180614 mentions some restrictions.
    Aruba-VSF-2930F# show tech transceivers
    Cmd Info : show tech transceivers
    transceivers
    Transceiver Technical Information:
     Port # | Type      | Prod #     | Serial #         | Part #
     2/51  *|    ??     |       ??   | unsupported      |
    * third-party transceivershow time
    Mon Jan  1 01:16:51 1990
    === The command has completed successfully. ===
    Logs.
    I 01/01/90 01:22:59 00406 ports: ST2-CMDR: port 2/51 xcvr hot-swap remove.
    W 01/01/90 01:23:15 00536 FFI: ST2-CMDR: port 2/49 Transceiver type not
                supported in this port.
    ----  Bottom of Log : Events Listed = 122  ----
    Aruba-VSF-2930F#
  • 6.  RE: Support for MILJET DAC on Aruba 2930F
    MVP GURU
    Posted Dec 27, 2019 08:04 AM
    The Aruba 2930F Switch series supports only the J8177D as "Copper RJ45" Transceiver.
    As reference have a look at ArubaOS-Switch and ArubaOS-CX Transceiver Guide (January 2019, 6th Edition) through which you should learn what transceiver is supported where.
    Clearly refer to Aruba 2930F QuickSpecs to see what transceivers are supported on that particular series.
