Switch security
Bit of a mixed bag of questions here but am now looking to secure my switch infrastructure and after looking at some configurations online (and comparing on my switch) I think the configurations are out of date.
I am using an HP-2530 (J9280A) and would like to know the command structure for the following features.
Sticky mac: The ability to detect and fix mac addresses of devices per port.
DHCP Snooping: enabling trust for a DHCP server (or trust of an uplink to the server) interface.
Any other useful tips or settings which can help lock down the switch from wrong doers.
Thanks as always.
Re: Switch security
I found this by googling "hpe arubaos-switch access security guide"  http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c05365163-4.pdf
Is that what you mean?
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Re: Switch security
Yes, very useful thanks. These commands match the model and firmware of my switch.
Interestingly enough I have also found the command "aaa port-access use-lldp-data" like LLDP/LLDP-MED which is already enabled on the switch this is a single command (as seen above).
Would this be all that is required in this case, run the command, plug in the phones and let them update the ports ?
Also any additional "show" commands to confirm the settings would be useful also.
MVP Expert
Re: Switch security
for VOIP, it is recommnaded to enable voice vlan (i will be auto configure LLDP)
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Re: Switch security
I already used LLDP-MED with my deployments of VOICE VLAN so this should already be enabled.
I assume then that the sticky mac feature for LLDP is an extra command/setting applied ontop of the VOICE VLAN feature.
Re: Switch security
Hi Eddie,
I am sure this link could help you too:
h22208.www2.hpe.com/eginfolib/Aruba/16.06/5200-5456/index.html#book.html
Regards
PS: If you feel this information is useful and solved your question or problem, please do not forget to mark it as a solution and give me some kudos.
