Wired Intelligent Edge
Switch update Schedule
  • 1.  Switch update Schedule
    Posted Oct 28, 2019 12:01 AM
    Hi Guys,
    Wish to understand if Aruba have like a schedule similar to Microsoft in terms doing update release for their fleet of switches?
  • 2.  RE: Switch update Schedule
    Posted Oct 29, 2019 03:20 AM
    With NetEdit, you can create a change to deploy simultaneously on multiple devices a selected firmware of the same switch type. During deployment you will be provided with a change validation that can check the health of your network before the upgrade and after the upgrade. For time being, this deployment can not be sceduled and triggered automatically.
  • 3.  RE: Switch update Schedule
    Posted Oct 29, 2019 06:34 PM
    Hi Vincent
    my question was not about how to deploy the update but more on schedule of new firmware releases from Aruba?
    Do they release a new version every month for instance 16.08 to 16.09  every month etcc.
    does this make sense?
  • 4.  RE: Switch update Schedule
    MVP GURU
    Posted Oct 30, 2019 01:53 AM
    I think @aruba_noob wishes to understand if a release schedule - roadmap with timeline - is available about ArubaOS-Switch (and/or ArubaOS-CX).
  • 5.  RE: Switch update Schedule
    Posted Oct 30, 2019 05:23 AM
    Thanks for clarification.
    Over the past years, the pace of AOS-CX releases is:
    - 2 major releases per year (major release means features introduction)
    Example: 10.2 was released in December 2018, 10.3 in June, 10.4 is coming very soon.
    - minor releases are essentially bug fixes and published every month.
    Example: 10.03.0040 was available early October, 10.03.0050 end of October.
  • 6.  RE: Switch update Schedule
    Posted Oct 30, 2019 05:39 PM
    thanks for the reply.
    is there a similar schedule for switches and AP?
