Frequent Contributor I
Switching HTTPS / Wildcard Cert
Do the Aruba 2900-series switches support having a wildcard cert in place for HTTPS? Code is 16.08
I have a created the appropriate TA-Profile, uploaded the signing CA certificate (intermediate), and generated the CSR with common-name *.domain.tld.
The wildcard cert does have *.domain.tld in the common-name.
When I try to copy the cert over I get "No matching CSR found. . . ". The same when I try
crypto pki install-signed-certificate
Super Contributor I
Re: Switching HTTPS / Wildcard Cert
I’m not sure about it but I think not.
You need both a private and public key and I think from my head its not poissible to import a private key, but not sure.
Is the csr generated on this switch?
Willem Bargeman ACMX#935 | ACCX #822
Please give me kudos if my post was useful!
If your issue is solved mark the post as solution!
Yes. With common name *.domain.tld which corresponds to the wildcard cert.
Assuming that wildcard certs are not accepted, is my only other route to get every CSR signed individually?
Super Contributor I
Yes indeed. As far I know EST is not support at the switches.
For more information see the documentation
http://h22208.www2.hpe.com/eginfolib/Aruba/16.08/5200-5483/index.html#c_Certificate_Manager.html
