Highlighted
Syntax AOS switchport mode of cisco
Im new at AOS, im trying to configure a 2930F switch, to this
interface
description
switchport access vlan
switchport mode access
storm-control broadcast level 1
storm-control action shutdown
switchport port-security
switchport port-security maximum 5
spanning-tree portfast
no snmp trap link-status
auto qos trust dscp
I want to know the equivalent from the switchport command from cisco to AOS, anyone could help?
Highlighted
MVP
MVP
Re: Syntax AOS switchport mode of cisco
ASOS Switches do not differentiate between switchport modes.
Thus, there is no command to set this.
Just add one untagged and several tagged vlans as needed.
vlan 10 untagged 22
vlan 30 tagged 22
To get an extended list for mapping between cisco and ASOS commands, please consult the guide linked at:
https://community.arubanetworks.com/t5/Wired-Intelligent-Edge-Campus/CLI-Reference-Guide-for-ArubaOS-CX-ArubaOS-Switch-Comware-and/td-p/491032
(Thanks, Parnassus :-))
Regards, Jö
Please give kudos, if you like my post.
Please Accept as solution, if my post was helpful.
