Highlighted
MVP Guru Elite
Re: TACACS with Cisco ISE and ArubaOS-Switch
Do you have a priv-level ?
Like https://www.arubanetworks.com/techdocs/ClearPass/Aruba_DeployGd_HTML/Content/HP%20Switch%20Integration/Switch_mgmt_TACACS.htm
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
No I dont see it.
https://community.arubanetworks.com/t5/Security/ArubaOS-Admin-Authentication-with-Microsoft-NPS/td-p/433832
This article is similar and the person is using attribute 4 with string root.
I tried the same but it doesnt work.
Access Type = ACCESS_ACCEPT
Aruba-Admin-Role = root
Highlighted
MVP Guru Elite
It is for RADIUS and Aruba(OS) Controller...
Highlighted
Ok thanks.
Any doc where I can find the exact value for Aruba switch shell?
