MVP Expert
Tailoring client fingerprinting logs
We've been rolling out client fingerprinting on our ArubaOS switches ( 16.8.[12])
While this works just fine, one problem is the amount of logging that goes on.
On our test switch the default loggig level isn;t too bad. On a production switch with lots of users it does seem t obe a case of "can't see the wood from the trees" if you want to look at anything else via "sh log"
Is there any way of limiting what gets logged whne you have fingerprinting enabled?
Rgds
Alex
