Highlighted
Frequent Contributor II
Time incorrect / 1hr ahead on Aruba 2930F - Using NTP
Hi all,
I'm using NTP on an Aruba 2930F, running the latest firmware. The thing is, my clock is an hour off and I can't understand why. I'm using us.pool.ntp.org which has always been accurate for me.
NTP configuration is as follows:
timesync ntp
ntp unicast
ntp server-name "us.pool.ntp.org" iburst
ntp enable
time daylight-time-rule user-defined begin-date 03/10 end-date 11/03
time timezone -420
At the time of this post UTC/GMT is 19:48. I'm in PST so the switch should be 12:48. Yet I'm getting 13:48 from the switch, indicating it's 1hr off/ahead.
Aruba-Lab-SW1# show time
Sun Aug  4 13:48:11 2019
NTP associations look good:
Aruba-Lab-SW1# show ntp associations
                            NTP Associations Entries
 Remote          St   T    When   Poll  Reach    Delay    Offset   Dispersion
 50.205.244.111  2    u    408    8     3        0.000    0.000    15.87941
And NTP status:
Aruba-Lab-SW1# show ntp status
 NTP Status Information
  NTP Status             : Enabled         NTP Mode        : Unicast
  Synchronization Status : Synchronized    Peer Dispersion : 0.00000 sec
  Stratum Number         : 3               Leap Direction  : 0
  Reference Assoc ID     : 0               Clock Offset    : -0.00021 sec
  Reference ID           : 50.205.244.111  Root Delay      : 0.05642 sec
  Precision              : 2**-18          Root Dispersion : 0.04622 sec
  NTP Up Time            : 0d 0h 8m        Time Resolution : 819 nsec
  Drift                  : 0.00000 sec/sec
  System Time            : Sun Aug  4 13:50:38 2019
  Reference Time         : Sun Aug  4 13:38:11 2019
Aruba-Lab-SW1#
I'm at a loss. Does anyone have any ideas here? I'm temporarily setting the timezone to -480 as a temporary fix but that doesn't seem right.
Thanks in advance!
Accepted Solutions
Highlighted
Re: Time incorrect / 1hr ahead on Aruba 2930F - Using NTP
Ah! - So I realized my mistake. I think what's actually needed (for this to happen automatically) is for me to set the timezone to PST and then set the daylight-time-rule to continental-us-and-canada.
The correct configuration should be:
time timezone -480
time daylight-time-rule continental-us-and-canada
Since I'm technically in the PST time zone, the switch now uses its internal calendar to set the time zone to PDT which is UCT -7 currently, even though I specified -480 in the config!
View solution in original post
All Replies
Highlighted
I redid the configuration you posted without the time daylight settings and the time is what you want, but when we do the time daylight setting, we are automatically within the time frame you entered in your setting (March 10th and ending November 3rd) and with that we have this difference reported.
Aruba-2930F-24G-PoEP-4SFPP(config)# show ntp status
  Reference Assoc ID     : 0               Clock Offset    : 0.00221 sec
  Reference ID           : 64.22.253.155   Root Delay      : 0.19228 sec
  Precision              : 2**-18          Root Dispersion : 0.07641 sec
  NTP Up Time            : 0d 0h 23m       Time Resolution : 819 nsec
  Drift                  : 0.00001 sec/sec
  System Time            : Sun Aug  4 13:20:53 2019
  Reference Time         : Sun Aug  4 12:45:29 2019
Aruba-2930F-24G-PoEP-4SFPP(config)# show time
Sun Aug  4 13:20:58 2019
Aruba-2930F-24G-PoEP-4SFPP(config)# show run
Running configuration:
; JL255A Configuration Editor; Created on release #WC.16.08.0001
; Ver #14:07.6f.f8.1d.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:24
hostname "Aruba-2930F-24G-PoEP-4SFPP"
module 1 type jl255a
timesync ntp
ntp unicast
ntp enable
time timezone -420
snmp-server community "public" unrestricted
vlan 1
   name "DEFAULT_VLAN"
   untagged 1-28
   ip address dhcp-bootp
   ipv6 enable
   ipv6 address dhcp full
   exit
Configuration with daylight
  Precision              : 2**-18          Root Dispersion : 0.07773 sec
  NTP Up Time            : 0d 0h 24m       Time Resolution : 819 nsec
  System Time            : Sun Aug  4 14:22:20 2019
  Reference Time         : Sun Aug  4 13:45:29 2019
Sun Aug  4 14:22:26 2019
timesync ntp
ntp unicast
ntp enable
time timezone -420
vlan 1
   name "DEFAULT_VLAN"
   untagged 1-28
   ipv6 enable
   exit
Highlighted
time timezone -480
