Unable to enable BFD on 54xx chassis with all v3 modules - error : BFD is not supported on V1 or V2
MVP
MVP
Problem:
When enabling BFD on a 5406Rzl2 chassis an error is thrown that "BFD is not supported on V1 or V2"  even though all the interface modules in the switch are v3
Diagnostics:
  • Check if any v1 or v2 interface modules are connected
HP-Switch-5406Rzl2# show modules
 Status and Counters - Module Information
  Chassis: 5406Rzl2 J9850A         Serial Number:   SG69GPR1QY
  Allow V2 Modules:   Yes
        Core  Mod
  Slot  Module Description                     Serial Number  Status   Dump  Ver
  MM1   HP J9827A Management Module 5400Rzl2   SG87G4C34Z     Active   YES   1
  A     HP J9990A 20p PoE+ / 4p SFP+ v3 zl2... SG68GPG2QH     Up       YES   3
  • In above case the only interface module connected is a v3 module. But we still get the error when we try to enable BFD
HP-Switch-5406Rzl2# configure terminal
HP-Switch-5406Rzl2(config)# bfd enable
BFD is not supported on V1 or V2 modules.
HP-Switch-5406Rzl2(config)# show bfd-session​
 Bidirectional Forwarding Detection (BFD) Information
 BFD Admin Status  :  Disabled
Solution
  • BFD is only supported in v3 modules and will not work with v2 modules
  • allow-v2-modules need to be disabled and the switch has to be reloaded to fix the issue
HP-Switch-5406Rzl2(config)# no allow-v2-modules
This command will disable all V2 modules and reboot the switch.
Continue (y/n)? y
Rebooting the System
  • The output of show modules after reboot looks like below
  Allow V2 Modules:   No
        Core  Mod
  • Now BFD can be enabled on the switch
  Administrative Status : Enabled
  Echo Source IP        :
  Maximum number of sessions supported         : 128
  Number of sessions reserved for internal use : 0
  Total Number of Sessions : 0
  Number of Sessions Up    : 0
  Number of Sessions Down  : 0
  Global Statistics:
  Total Number of Control Packets Transmitted  : 0
  Total Number of Control Packets Received     : 0
  Total Number of Control Packets Dropped      : 0
  Session  VLAN   Source IP        Destination IP   Echo       State
 Application
Version history
Revision #:
1 of 1
Last update:
‎04-02-2020 02:09 PM
Updated by:
