User-Roles Disabled on 2930M by Default
Does anyone know how to enable the user-role functionality on a 2930m? I can't seem to find any documentation on this, and from what i can find it appears that it is enabled by default. From the GUI there isn't much and from the CLI ive tried the obvious "?" and "tabs" to no avail.
Aruba-2930M-48G-PoEP# show user-role
User Roles
Enabled : No
Initial Role : denyall
Type Name
predefined denyall
 Software revision  : WC.16.07.0002
Thanks.
Re: User-Roles Disabled on 2930M by Default
For anyone who may need it, this was the command:
aaa authorization user-role enable
This warning follows, FYI: Some legacy secure client access functionality is not supported when user roles are enabled.
Please refer to the end user documentation for details.
Take a look at the ClearPass Solution Guide for Wired Policy Enforcement.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
