Highlighted
MVP Expert
User authorization on AOS-switches: default or role-based approach?
Hi community,
When authenticating users on AOS-switches there are two approaches:
  1. Default: the RADIUS server such as ClearPass has settings such as VLAN assignments and ACLs configured on it as RADIUS standard attributes or vendor-specific VSAs. When a user successfully authenticates, ClearPass sends these attributes in the Access-Accept message to the switch, and the switch then applies them.
  2. Role-based authorization: the RADIUS server can simply send the switch the name of the user’s role in the Access-Accept message. The role name matches a role configured on the switch, and this role defines settings such as VLAN assignment, ACL, rate limit, and QoS priority, which the switch then applies to the user session.
If I am not going to use per-user tunneled-node, which imposes the switch to use role-based authorization, which approach shall I use? Which one is better? What are the upsides and downsides of each one?
Julián
Accepted Solutions
Highlighted
Re: User authorization on AOS-switches: default or role-based approach?
Role based is almost always recommended, you do not need to do user-based tunneling to use user roles.  We've added many attributes to user roles as well in ArubaOS-Switch 16.08.  It's much easier to pass a user role back than multiple VSAs.
User roles can contain:
QoS/ACL Policy
Rate Limits
PoE settings
Port-mode (for APs)
VLAN Assignment
Reauth timers
However, either way will work.
Link to User role section in the Access Security Guide.
http://h22208.www2.hpe.com/eginfolib/Aruba/16.08/5200-5488/index.html#Local_User_Roles.html
Justin
View solution in original post
All Replies
Highlighted
QoS/ACL Policy
Rate Limits
PoE settings
Port-mode (for APs)
VLAN Assignment
Reauth timers
Justin
Highlighted
Moderator
Validated designs and testing on the policy side are only done using user roles.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Highlighted
MVP Expert
And I guess it's simpler to use DUR configured once and centralized on CPPM than configure the same roles distributed on every switch... Am I right?
Julián
