VLAN Implementation
Hi there,
Correct me if I am wrong.
I would like to implement a VLAN here in my company.
Currently my network design here is flat network.
Can we create a multiple VLAN inside a core switch but all connecting switch from the core switch to idf switch is only unmanaged.
See attached image for my idea.
Sorry for the design.
Super Contributor I
Re: VLAN Implementation
If the access switches are unmanaged it's not possible to implement multiple VLAN's.
Or you should place every switch in a different VLAN. So every client behind that switch is in the same VLAN
Willem Bargeman ACMX#935 | ACCX #822
Please give me kudos if my post was useful!
If your issue is solved mark the post as solution!
You mean that, its not possible to connect 2 to 3 hosts with different vlan to  a access switch?
My problem is every area or quadrant in my company has a different employee that access internet and I want to isolate my workstation and servers from them.
Maybe I suggets to implement vlan to my access switch.
Super Contributor I
You should implement VLAN's at the access switches to achieve this. Without VLAN's at the access switches this is not possible.
