Highlighted
Occasional Contributor I
VLAN Routing - Aruba 2930F
Hi Guys,
I need some assistance, very new to the networking.
I have x2 Vlans setup on my Aruda Switch.
VLAN 152 (VLAN interface IP: 192.168.153.249/23)
VLAN 154 (VLAN interface IP: 192.168.155.249/23)
The VPNs are tagged on one port and connected to a WatchGuard firewall.
WatchGuard Firewall:
One VLAN Interface:
VLAN 152 (VLAN interface IP: 192.168.153.250/23)
VLAN 154 (VLAN interface IP: 192.168.155.250/23)
There seems to be some routing issues as I’m getting major latency between VLAN152 and VLAN154.
Attached is the firewall config file (please ignore the other range (192.168.105.0/24) as I’m only utilising ports 46, 47, 48)
PORT 46 – untagged VLAN152
PORT 47 – untagged VLAN154
PORT 48 – Tagged on both VLANs
PORT 48 – plugged into firewall
Accepted Solutions
Highlighted
MVP Expert
Re: VLAN Routing - Aruba 2930F
Greetings!
The switch itself does not appear to be performing any routing (the 'ip routing' command is not present in the posted configuration), so it is likely that any latency being observed is being introduced by a device upstream of the switch.
Are you also observing latency between the switch and either of the upstream firewall IP addresses (192.168.153.250 or 192.168.155.250) or the switch default gateway 192.168.105.250?
Matt Fern
Senior Technical Marketing Engineer, Aruba Switching
Aruba, a Hewlett Packard Enterprise company
8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747
T: 916.540.1759  |  E: mfern@hpe.com   |   Matt @ Twitter
View solution in original post
All Replies
Highlighted
MVP Expert
Greetings!
Matt Fern
