Highlighted
VLAN number re-mapping
I need to present a number of VLANs on a single connection between an Aruba 5406R and an external network. My issue is that several of the VLANs need to re-numbered "in transit".
This would be relatively trivial on Comware, however I cannot find an equivalent command in ArubaOS-Switch.
Any ideas?
Pete
Accepted Solutions
Highlighted
MVP Guru
Re: VLAN number re-mapping
I'm afraid that the VLAN Id translation/remapping feature (during transit) was never developed/introduced on ArubaOS-Switch (or older HP ProVision) based switch series...so you're not going to be lucky with an Aruba 5400R zl2 switch series.
I know for sure it was introduced on ArubaOS-CX based switch series (and not since beginning...but starting from 10.03.0001 IIRC).
View solution in original post
All Replies
Highlighted
MVP Guru
Highlighted
MVP Guru Elite
but not on all ArubaCX product... (only 83xx and after ?)
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
MVP Guru
@alagoutte wrote: but not on all ArubaCX product... (only 83xx and after ?)
Exactly Alexis, you're right!
The VLAN translation feature was, at least initially (ArubaOS-CX 10.03), introduced only on Aruba 8320, 8325 and 8400X Switch series because those hardware platforms were the only available at time...but with the subsequent release of ArubaOS-CX 10.04 (and newer 10.05) that feature was extended also to Aruba 6300/6400 Switch series (I'm not sure it is really available on the Aruba 6200 too [*]).
[*] On the ArubaOS-CX 10.05 Command-Line Interface Guide for Aruba 6200 Switch Series there aren't references about vlan translation and show vlan translation commands found instead on CLI Guides related to Aruba 8320, 8325, 8400X and 6300/6400 Switch series.
Highlighted
MVP Guru
Today, VLAN translation is available on all AOS-CX switches , except 6200.
Highlighted
MVP Guru
Thanks Giles for confirming about Aruba 6200!
