Highlighted
VRF number for Aruba 8400 and 8320
Does anybody know how many VRFs can be created and used simultaneously in an Aruba 8400 and 8320 for the last version of firmware AOS-CX v10.01?
Regards
PS: If you feel this information is useful and solved your question or problem, please do not forget to mark it as a solution and give me some kudos.
Accepted Solutions
Highlighted
MVP Guru
Re: VRF number for Aruba 8400 and 8320
Highlighted
Hi Pedro,
You can trust Vincent :-) This is from one of the presentations that we presented during Atmosphere EMEA 2018.
Kind regards,
Dik
View solution in original post
All Replies
Highlighted
MVP Guru
Highlighted
Thanks for your answer Vincent.
Do you have a document to support your answer?
Regards
Highlighted
Hi Pedro,
Kind regards,
Dik
Highlighted
Hi Dik,
I have sent you an internal message. I would really appreciate your help.
Regards
Highlighted
MVP Guru
Highlighted
Hi Vincent,
I was given access to the Atmosphere 2018 presentations and in one of them (Anatomy of the Aruba 8400 and 8320 with ArubaOS-CX" by Scott Koster) I found the same slide with a big star that says "coming soon".
Wich presentation is more recent: EMEA Webinar or Atmosphere?, I am a bit confused, is 32 VRF-Lite instances an available feature for this AOS-CX version or is a future one?
Regards
Highlighted
Hi Vincent.
I have one more question.
As far as I have seen, VRF and VRF-Lite are two different features:
https://ipwithease.com/vrf-vs-vrf-lite/
What I have asked is about VRF (not VRF-Lite). Can you confirm me that Aruba 8400 and 8320 implement the complete VRF feature?
Regards
Highlighted
MVP Guru
I will not comment on the accuracy of using VRF word in the blog you refer to, instead of less confusing wording like MPBGP/L3VPN. Bottomline for 10.1:
8320/8400 supports 32 VRFs, and does not support yet MPBGP/L3VPN.
When and which version will support MPBGP/L3VPN, please connect to the ATM speaker Scott Koster, who owns the software roadmap.
Thanks.
Highlighted
Hi Vincent,
Do you know if the number of VRF have been Up more than 32 in the new arubaOS-CX (10.03)?
They are no informations in datasheet or others docs..
Thank you.
Sébastien
