Hey all,
one short question..
The Datasheet from the Aruba 8320 says:
VRRP
Allows groups of two routers to dynamically back each other up to create highly available routed environments.
Normally i can create a VRRP with more than two routers. Is there really this limitation or can i create a VRRP with four 8320 Switches?
thank you!
