Re: VSF Stacking on 2930f
yes, i've tested and it works. so is possible. thanks
Dears
Can you please let me know if i have THREE 2930F switches and i want to stack them(VSF) so what commands should i run on each switch to put all of them in stack. Kindly share the step by step commands.
Cheers
Umer
I just recently did a setup with 3 switches and finally got them to stack correctly.   Here is the post that helped me - Configure Virtual Switching Framework (VSF) the easy way
basically you configure the port that you will use as the uplink to a Link port (vsf member # link # <port>) and then connect the new switch to that port  while the new switch is off.  Then power it on and it should be detected and setup in the VSF.
When you are ready to link them into a loop, you can then add a second Link port with a different number (1-2) and then connect the cables.  To get the loop to detect it MAY take a reboot.
Plese tell me how...
i want to do the same. two 2930F just with SFP (not SFP+) and VSF Stacking.
Best
