Hi
I would like to confirm this scenario and see if there is any alternative to this
Current Scenario:
2x 5400 chassis running VSF
MAD LACP enabled
Member 1 priority 255 - Master
Member 2 priority 100 - Stanby
Member 1 has fibre links coming in from the access switches as well as various copper links for servers, Firewall etc.
Member 2 has only the redundant fibre links coming in from the Access switches
Future Scenario:
Member 1 goes down Member 2 takes over as Master
Member 1 comes up stays as Standby - no preempt option available
network continue to run
Then..
Fibre break between the two 5400 Cores MAD LACP now
shutsdown Member 1 as it is the standby member
This will now be an issue as the servers and firewalls connected to Member 1
will be down and the company will not be able to operate
So I would like to know
Am I correct with the above?
I have read elsewhere that MAD will not shutdown all interfaces
but only the interfaces for any device with redundant links to
both members in which case the servers and firewalls will stay up
However if all interfaces in member 1 will be shut is there any workaround
to this other than reloading member 2so it comes back as standby?
thank you
