So here is where I am at currently,
From within the switch CLI i can ping across my transfer Vlan to other internal network on a differnet port on the firewall. But, when I am on client PC using a vlan (testing with 50) I can not ping anything past the local switch, not even the other end of my transfer vlan. I can ping from a client on vlan 50 to a client on vlan 52.
Now if I am on a client that is in the transfer vlan I can ping my side, the firewall side and the other internal network. all is good! But I cant ping my test pc on my vlan 52.
Sounds like a static route issue on the 2930, yes?
Here is my current config.....
Running configuration:
; JL324A Configuration Editor; Created on release #WC.16.08.0001
; Ver #14:07.6f.f8.1d.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:24
hostname "Core Switch Aruba-2930M"
module 1 type jl324a
trunk 1-2 trk1 lacp
trunk 3-4 trk2 lacp
trunk 5-6 trk3 lacp
trunk 7-8 trk4 lacp
trunk 9-10 trk5 lacp
trunk 11-12 trk6 lacp
trunk 13-14 trk7 lacp
ip route 0.0.0.0 0.0.0.0 192.168.2.254
ip routing
(removed)
snmp-server community "public" unrestricted
oobm
ip address dhcp-bootp
ipv6 enable
ipv6 address dhcp full
exit
vlan 1
name "Not Used"
no untagged 18,20-24,Trk1-Trk2
untagged 15-17,19,Trk3-Trk7
no ip address
ipv6 enable
exit
vlan 2
name "Vlan 2 Transfer"
untagged 18
tagged 24
ip address 192.168.2.249 255.255.255.248
exit
vlan 5
name "Vlan 5 Network Management"
untagged 23
tagged Trk1-Trk2
ip address 192.168.5.5 255.255.255.0
exit
vlan 10
name "Vlan 10 Wireless Employee"
no ip address
exit
vlan 12
name "Vlan 12 Wireless Supervisor"
no ip address
exit
vlan 20
name "Vlan 20 Wireless Visitor"
no ip address
exit
vlan 25
name "Vlan 25 AP Control"
no ip address
exit
vlan 40
name "VLAN 40 Voice"
tagged Trk1
ip address 192.168.40.5 255.255.255.0
voice
exit
vlan 50
name "Vlan 50 Die Shop"
untagged 22
tagged Trk1
ip address 192.168.50.5 255.255.255.0
ip rip 192.168.50.5
exit
vlan 51
name "Vlan 51 Packaging"
untagged 21
tagged Trk2
ip address 192.168.51.5 255.255.255.0
exit
vlan 52
name "Vlan 52 Thermal Paint"
untagged 20
tagged Trk3
ip address 192.168.52.5 255.255.255.0
exit
vlan 53
name "Vlan 53 Shipping"
tagged Trk4
ip address 192.168.53.5 255.255.255.0
exit
vlan 54
name "Vlan 54 Maintenance"
tagged Trk5
ip address 192.168.54.5 255.255.255.0
exit
vlan 60
name "Vlan 60 Office"
tagged Trk6-Trk7
ip address 192.168.60.5 255.255.255.0
exit
spanning-tree Trk1 priority 4
spanning-tree Trk2 priority 4
spanning-tree Trk3 priority 4
spanning-tree Trk4 priority 4
spanning-tree Trk5 priority 4
spanning-tree Trk6 priority 4
spanning-tree Trk7 priority 4
