My customer is migrating from Cisco to Aruba 2930M. For iSCSI switches, the flow-control mode he has is "receive desired", while in Aruba I can only enable or disable flow-control in ports.
Any idea is I can simply enable flow control on these ports? Is there any scnario where this configuraiton may cause troubles if the other side has flow-control disabled?
In Aruba configuration, I am planning to simple enable flow-control in these ports
interface 1/1
flow-control
