Highlighted
need help to pointed me to 2930F,2930M and 8325 Aruba OS-CX configuration documents
Hi Team
I'm new to Aruba platform and haven't used it before
but I would love to learn more about the configuration and command-line interface, can you please point it of where I can find configuration documents (Cs , As and 72xx controller configuration documents)
thanks
Accepted Solutions
Highlighted
Re: need help to pointed me to 2930F,2930M and 8325 Aruba OS-CX configuration documents
You can find all the configuration documents on the below link
https://asp.arubanetworks.com/downloads
Please select document and appropriate switch or controller model to get the relevant information
To simplify below is for switches:
https://asp.arubanetworks.com/downloads;fileTypes=DOCUMENT;products=Aruba%20Switches
Below for Controllers:
https://asp.arubanetworks.com/downloads;fileTypes=DOCUMENT;products=Aruba%20Mobility%20Controllers%20%28AOS%29
View solution in original post
All Replies
Highlighted
