Highlighted
Regular Contributor II
power-over-Ethernet command - disable for laptops?
Possibly a silly question; but it is best practice to use the “no power-over-Ethernet” command for all switchports except the ones we know definitely need it (VOIP phones etc)
Accepted Solutions
Highlighted
MVP Guru Elite
Re: power-over-Ethernet command - disable for laptops?
You can... if you want... but for me not really a "best" (good) pratice
(there is a special "protocol" on PoE device for search if the port is PoE or not...)
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
View solution in original post
All Replies
Highlighted
MVP Guru Elite
