Logging Errors 00828 lldp: PVID Mismatch on Port
MVP
MVP
Problem:
The logging buffer reports recurring informational messages similar to the ones given below :
I 06/09/12 14:17:16 00828 lldp: PVID mismatch on port L1(VID 1)with peer device
            port 265(VID unknown)(1)
I 06/09/12 09:11:53 00828 lldp: PVID mismatch on port L1(VID r
            device port 265(VID 1)(1)
Diagnostics:
Solution
The Port VLAN ID (PVID) is one of the optional TLVs (Type, Length, Value) carried in LLDP frames as part of the protocol operations. The PVID for a given port indicates the VLAN ID that will be associated with an untagged data frame received on the port.
In the following example, switch Rack2sw1 has been intentionally misconfigured to recreate the error. Rack2sw1 does not have an untagged Vlan configured for port L1.
The configuration, verification, and testing associated with the diagram follows:
Vlan Configuration:
Rack2sw1# show running-config vlan
Running configuration:
vlan 1
   name "DEFAULT_VLAN"
   tagged GDP,GUP,HDP,HUP
   no untagged L1 <-----
   untagged A1-A24,B1-B24,C1-C24,D1-D24,F1-F24,J1-J4,K1-K4,L2-L4
   ip address 192.168.2.1 255.255.255.0
vlan 12
   name "VLAN12"
   tagged L1
   ip address 192.168.12.1 255.255.255.0
Rack2sw2# show running-config vlan
vlan 1
   name "DEFAULT_VLAN"
   untagged A1-A24,B1-B24,C1-C24,D1-D24,E1-E2,G1-G24,H1-H2,J1-J4,K1-K4,L1-L4
   ip address 192.168.2.2 255.255.255.0
vlan 12
   name "VLAN12"
   tagged L1
   ip address 192.168.12.2 255.255.255.0
Vlan Verification:
Rack2sw1# show vlans ports l1 detail
 Status and Counters - VLAN Information - for ports L1
  VLAN ID Name                 | Status     Voice Jumbo Mode
  12      VLAN12               | Port-based No    No    Tagged
Rack2sw2# show vlans ports l1 detail
  1       DEFAULT_VLAN         | Port-based No    No    Untagged
Configuration change/verification:
Rack2sw1(config)# vlan 1 untagged l1
Testing:
Rack2sw1# ping 192.168.2.2
192.168.2.2 is alive, time = 2 ms
Rack2sw1# ping 192.168.12.2
192.168.12.2 is alive, time = 1 ms
Physical interconnect:
Rack2sw1# show lldp info remote-device
 LLDP Remote Devices Information
  LocalPort | ChassisId                 PortId PortDescr SysName
  L1        | 00 18 fe ef a5 00         265    L1        Rack2sw2
Rack2sw2#  show lldp info remote-device
  L1        | 00 17 08 cd 05 00         265    L1        Rack2sw1
Version history
Revision #:
1 of 1
Last update:
a month ago
Updated by:
