Highlighted
Re: AP boots as only AM mode.
have you try with other regularity domain than the default , generaly AM mode is used to unregistred AP type.
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Highlighted
Contributor I
No I have not. Japan only.
I thought I didn't need to try with other domain  because another IAP205 worked well.
But I will try that.
Thank you.
Highlighted
any way ,
i got the same probleme with IAP 103 (first i was using algeria reg domain), and to resolve the probeme i change the IAP regularity domain into France.
check also the last firmware update.
Raouf CHAHBOUNE
Highlighted
Contributor I
 Sorry for late.
I confirmed that this issue was replicated inspite of the same domain configuration.
And I found a workaround.
This issue occurs in Aruba OS 6.4.1.0, but does not occur in Aruba OS 6.4.2.2.
So this might be a bug.
Thanks.
Highlighted
@atsushi wrote:
 Sorry for late.
Thanks.
the versionn 6.4.2.3 is better , they fix many issue , the version 6.4.2.2 was removed from the support site
Raouf CHAHBOUNE
Highlighted
 So you manage to solve this by upgrade the image to 6.4.2.2. or 6.4.3.2 ?
I face the same problem here.
Highlighted
Contributor I
Hi, Mandyvoon
Sorry for late.
Yes, I did.
