Occasional Contributor I
303h problem
I have a 303h that I am trying to setup for a personal network at my house. I see the SetMeUp SSID as long as the switch I have it connected to has no internet connection via a Ubiquity AirMax bridge. I am using PoE to power the 303h. Once, I connect the switch to the internet, the 303h stops broadcasting wifi and seems to go into a constant rebooting loop. Any idea on whats wrong? I have very little networking experience. Thank you
Re: 303h problem
Is is possible that another party deployed this AP before you?
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Re: 303h problem
yes. I factory reset it though.
Re: 303h problem
I can connect to the switch directly with a LAN cable and my computer can connect to the internet without any problems.
MVP
MVP
Re: 303h problem
Most likely the AP is zerotouch provisioned (ZTP) through "aruba activate" or "cloud central", you should see the process when you have a serial cable connect to it. You can also follow the traffic through your firewall and looking for outgoing traffic to (i guess) *.arubanetworks.com
For detach from ZTP you have to contact TAC support.
Or simply block the outgoing connection on your firewall, lol ;)
Kind Regards Marcel Koedijk
HPE ASE Flexnetwork | ACMP | ACCP | Ekahau ECSE Design - Was this post usefull, Kudos are welcome.
MVP
MVP
Re: 303h problem
Re: 303h problem
 Thank you. Stupid question, how would I go about blocking the outgoing connection on my firewall? thank you
