Highlighted
3600 supported ap firmware
Good afternoon Chaps
Does anybody have a link or information on what firmware versions the 3600 Controller should support.
I have obviously check the data sheet and cannot see anything listed.
A customer of mine has gone and bought one second hand of course without doing any recon and of course left it for me to look into.
They have a mix of aruba AP 105, 215 and just want to confirm which versions are supported
any assistance would be greatly appreciated
Regards
Dan
Accepted Solutions
Highlighted
MVP Guru
Re: 3600 supported ap firmware
 You can find the latest supported firmware on the EOL page. For a 3600 controller, you will be able to run ArubaOS 6.4.x which supports the AP105 and AP215.
https://www.arubanetworks.com/en-gb/support-services/end-of-life/
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
View solution in original post
All Replies
Highlighted
MVP Guru
Highlighted
Hello Criag
Thank you got the quick response greatly appreciated!
Thank you for the link that will be very Valuable!
Kind regards
Dan
