Hi all,
After the survey, the conclusion was that our 2.4Ghz band on the office was unusable. So the goal is trying to connect as many of the clients to 5Ghz. When roaming we got sometime the issue that the client falls back to 2.4Ghz.
The setup: 2 x 7010 Aruba controller + MM, 315 series AP's. ArubaOS 8.3.
The configuration that I already tried:
* Enabling 802.11 r/k/v;
* Enabling ClientMatch/AirMatch;
* Band steering: Force 5Ghz.
Anybody else got some ideas? Was thinking about raising the minimum power level on 5Ghz?
Thanks in advance!
Kind regards,
Thomas Willems
