Highlighted
Contributor I
Re: 7005 vs. 9004 MC
Hi Marcel,
can you confirm that the 9004 Gateway can work as a standalone controller?
I see it's mentioned in the datasheets but it also infers that a Mobility Master might be needed, could you please clarify this for me?
Best regards,
Aarón
Highlighted
MVP Expert
Hi Aaron,
The 9004 can be used as standalone controller with or without a MM.
Julian
Highlighted
MVP Expert
MVP Expert
There is SD-WAN and Controller based firmware. When you install the controller firmware you can run a 9004 in standalone mode without the need of a Aruba Mobility Master.
  • SD-WAN Mode – Aruba Central Foundation or Foundation Base Licenses (9004 and 9012 are supported)
  • ­ Controller Mode – AP License (9004 supported as of ArubaOS 8.5, and 9012 will be supported in a later release)
When you flashed the controller through Aruba Cloud Central it will install the SD-WAN firmware. You can download the controller based firmware here; https://asp.arubanetworks.com/downloads/software/RmlsZTo2NTRiMzdmNi03NmI0LTExZWEtOTY0NC0xMzRlYzBjMzEwNzg%3D
Kind Regards Marcel Koedijk
HPE ASE Flexnetwork | ACMP | ACCP | Ekahau ECSE Design - Was this post usefull, Kudos are welcome.
Highlighted
Contributor I
Thank you
Highlighted
MVP Expert
MVP Expert
In this topic you see a image of working 9004 controller image (with mobility master) ;). MM is not required for a standalone controller!
https://community.arubanetworks.com/t5/Wireless-Access/Standalone-9004-or-7005-with-8-5-0-X-all-version-ALE-error/td-p/655527
In the 9004 datasheets you can find your clear statement Also how many AP can be terminated in controller mode.
https://www.arubanetworks.com/assets/ds/DS_9000Series.pdf
7005 = 16 AP's
9004 =  32 AP's
The 9004 controller is excellent choice ;;)).
