Highlighted
Occasional Contributor I
7210 controller not ping with each oter
hi,
my client has four controller two in HQ and another two in remote location. when we try to ping a local controller from master its not pinging. when we increase the packet size to 2000 its ping with 100% success.can you please help me in that.
because on master controller all the AP's which are connected to local controller shows down.
also on airwave i am not able to see any client with AP's that connected to local controller.
Highlighted
Re: 7210 controller not ping with each oter
Can u run [show switches] on the master controller please
Can u run [show log errorlog all] on the master controller please.
share the outputs with us.
(Do u able to ping the specific local controller IP from a different equipment ? for example from the GW or another switch on the same segment )
U sure , That the tunnel between master and that specific local is up and running?
More info in another AirHeads post:
https://community.arubanetworks.com/t5/Controller-Based-WLANs/Understanding-and-Troubleshooting-Master-Local-controller-issues/ta-p/239727
Highlighted
output of show switches
i am able to ping the other device in that segment.
Highlighted
hi my local controller also not show me the client details like avg signal quality,speed,usage. it only show me the client name with connected AP,s .
Highlighted
MVP Guru
Are you seeing this in the GUI or via the CLI? Feel free to post a screenshot showing this.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Highlighted
on gui
Highlighted
MVP Guru
Any chance of a larger screenshot? Its quite small so difficult to make out the details...
Highlighted
Highlighted
on cli its showing all the details
