Highlighted
802.11ax - Aruba AP-515 and Samsung Galaxy S10
The first 802.11ax client Samsung Galaxy S10 was released.
Just performed the 802.11ax connectivity test with our Aruba AP 515.
Below are some of the screenshots.
AP Association Table for 2.4Ghz:ap assoication 2Ghz.jpg
AP Association Table for 5Ghz:ap association 5Ghz.jpg
MCS Rates:MCS Rates Radio 0.jpg
2.4Ghz band - Client View in GUI:Client View 2 Ghz.jpg
5Ghz band - Client View in GUI:Client View 5 Ghz.jpg
WiFi6 in Samsung Galaxy S10:
Have a look at the WiFi Symbol :)Samsung S10 5Ghz.jpg
Hope you find this post useful. Please let me know your feedback!
Kapil
Highlighted
Re: 802.11ax - Aruba AP-515 and Samsung Galaxy S10
Thanks for sharing !
Camil | ACDX #1215
Highlighted
Curious, does the S10 have the WPA3 Security Option?
Did you try it with the AF-515?
Highlighted
Samsung Galaxy S10 doesn't have WPA3 option.
Yes, I tested with AP-515
Highlighted
Interesting, good to know!
Charlie Clemmer
Aruba Customer Engineering
Highlighted
The new Android Beta has Enhanced Open and WPA3-Enterprise listed as security options:
https://www.google.com/android/beta
You will need a  Pixel to enroll.
Highlighted
Thanks! Just opt-ed in my Pixel.
Charlie Clemmer
Highlighted
Frequent Contributor II
Good and Thanks
Thank you,
Ratchapas S.
Land of Smiles
Highlighted
MVP Expert
MVP Expert
Thanks for sharing, really intressting
Kind Regards Marcel Koedijk
HPE ASE Flexnetwork | ACMP | ACCP | Ekahau ECSE Design - Was this post usefull, Kudos are welcome.
Highlighted
Contributor I
Really?
At https://www.wi-fi.org/product-finder (Wi-Fi Alliance) can i find that many S10 Devices are WPA3 certifieded, so i thought it will be direct avaible. Maybe in a future software release ?!?
