Highlighted
AOS 8.4 cluster / an internal system error
Hi Airheads.
I encouted a strange issue with aos 8 classic cluster
Cluster is up but client cant get ips
I disabled the cluster , and everything working.
When checking the errorlog im getting this strange output:
Apr 5 16:55:04 311020> |AP 48:4a:e9:c1:b9:ec@10.107.50.102 sapd| An internal system error has occurred at file sapd_cluster.c function sapd_cluster_standby_hello_cb line 749 error sapd_cluster_standby_hello_cb: Unexpected result code NOT_SUPPORTED_AP_TYPE, node state:init.
Apr 5 16:55:07 311020> |AP 48:4a:e9:c1:b9:ec@10.107.50.102 sapd| An internal system error has occurred at file sapd_cluster.c function sapd_cluster_standby_hello_cb line 749 error sapd_cluster_standby_hello_cb: Unexpected result code NOT_SUPPORTED_AP_TYPE, node state:init.
Apr 5 16:55:09 311020> |AP 48:4a:e9:c1:b9:ec@10.107.50.102 sapd| An internal system error has occurred at file sapd_cluster.c function sapd_cluster_standby_hello_cb line 749 error sapd_cluster_standby_hello_cb: Unexpected result code NOT_SUPPORTED_AP_TYPE, node state:init.
Apr 5 16:55:11 311020> |AP 48:4a:e9:c1:b9:ec@10.107.50.102 sapd| An internal system error has occurred at file sapd_cluster.c function sapd_cluster_standby_hello_cb line 749 error sapd_cluster_standby_hello_cb: Unexpected result code NOT_SUPPORTED_AP_TYPE
Any idea ?
Whats causing the error ?
Highlighted
MVP Expert
Re: AOS 8.4 cluster / an internal system error
What type of AP are you using ?
Thank you
Victor Fabian
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Highlighted
AP-345
Highlighted
MVP Expert
I recommend you downgrade to AOS8.3.0.6 (most stable version)
Unless you are looking to use a particular feature in AOS8.4
Thank you
Victor Fabian
Thank you
Victor Fabian
Highlighted
But i have on the same mm other group that working wonderful as a cluster with AP-345
8.4 GUI is much baked than 8.3.0.x
Any idea what causing this issue ?
Highlighted
Are you sure that the client VLAN is trunked to the controller?  The AP messages might have nothing to do with the client issue.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Yes..
Triple time checked and verified it.
Tagged ab eth port on the controller with the needed vlan an got it..so the needed vlan arriving and functional but not when cluster is enabled.
BTW:
When cluster is disable its working
Highlighted
Highlighted
I'm running with same AOS 8.4 and cluster is wokring fine.
can you rechek below another configration points:
1. Cluster profile and Exclude vlans list.
2.And allowed vlans and native vlan id list under interfaces of MC's
3. did you see any output like
>show lc-cluster group-membership if its not connected then there is issue with version/limitation/physcial connectivity issue/IPSec tunnel setup issue.
Highlighted
Issue solved couple weeks ago.
(Wrong Vlan was in the cluster)
found out by using the following command , what the wrong VLAN was,
show lc-cluster vlan-probe status
